Thanks for the help going to start to practice unsoldering and soldering very small surface mount chips better not drink to much coffee.
Can practice on old cluster just not the eeprom chip until I get really good.
Where does it get the signal from? Is it at the wheel ABS signal?
Is there any other way to get the odometer updated on a new cluster that reads 0km I have read that you can change the reading if it is 100 km or less to the new reading but only once.
The eeprom memory in the new cluster is a surface mount chip that is very small about 3mm by 3mm and 8 solder points.
If I could get the eeprom chip off the old cluster and put it on the new one would that work without programming it?
Hi just got a new cluster but it reads 0KM how can I get the original KM?
1997 van camper with VR6 automatic transmission.
Live in Canada
