Hi everyone sorry for the english, i posted the below on an old thread while trying to send a email to a forum member ( sorry couldn't read the german) So I now have found my way around the forum a little bit and thought I might get a better response if i posted in the right place ..Hope this is ok......
Hi everyone thanks for the warm welcome....
1999 2.5 Acv. Bought the van with a faulty gearbox so i bought a very low mileage ( 1000km) gearbox and torque convertor which had been reconditioned. I had the gearbox and convertor put in but its still not quite right. When i get to 55mph it changes down a gear and the revs go from 2 thousand to 2.5. I also get odd random gear change..
If i plug the van into Vagcom i sometimes get a 01192 ( torque convertor lock up clutch..intermittent) fault..I was getting this fault with the other faulty box and convertor. I can't believe i have been unlucky enough to have 2 bad convertors...
I have taken it to various people and they are convinced it isn't a faulty box or convertor. The van drives very nice through town at low speeds..
The last person i took it to has been working with Autoboxes for 50 years, he plugged the van into a laptop and checked everything, he is 99% sure that the ECU is faulty as it was even giving strange random readings even while the van wasn't moving...The potentiometer etc were all ok...
So my question is what is the difference between all the Ecu part numbers...The one in my van is 01P 927 733 AK, I can get an ECU which ends 733 BS but i can't work out if they are all different and if the all work with other vans..
The van is fitted with an extra oil cooler for the box ( it onlys gets to 98 degrees after a 100k journey) so heat isn't a problem..
I think i am nearly there with this box, I have set the shift pattern to 00007 but it still feels like it is struggling on the autobahn...
Thanks very much for any advice this looks like a really good forum...even though i can't understand most of it........
Anthony
