I hope i am welcome to post in english .
Hi Im looking at VCDS fault codes for 098 Auto transmission
7 faults found:
00266 - Solenoid Valve 5 (N92)
36-00 - Open Circuit
00293 - Multifunction Switch (F125)
25-10 - Unknown Switch Condition - Intermittent
00300 - Transmission Fluid Temp Sensor (G93)
34-10 - No Elaboration Available - Intermittent
00518 - Throttle Position Sensor (G69)
16-10 - Signal Outside Specifications - Intermittent
00596 - Short Between Solenoid Valve (or Injector) Wires
35-10 --- Intermittent
00652 - Gear Monitoring
27-10 - Implausible Signal - Intermittent
00641 - ATF temperature
06-10 - signal too high - intermittent
After clearing faults
Remains so i suspect i may have to replace this solenoid.
I want to test the connection but my connector is not round like i see in pdf documents but rectangle with only 6 wires. So id like to check for continuity but not sure which pins. Also Id like to order solenoids and ribbon cable but now im not sure which one. Any help is appreciated Here is a pic of the connector style
